Need the detailed advice of a competent electrician pls
Postby Proph » Sun Dec 11, 2016 11:55 am
Hi guys, I want to add an ignition only fuse box which will be located in the boot next to the battery.
I have a few 12v accessories I want to connect which obviously will only be powered when the ignition is on, I understand I need a 6-8 connection fuse box, a 4 prong relay and an in line fuse from battery to relay, question is how will I locate or run a new ignition wire without pulling up the entire centre console which Cornish has done successfully but I've been unable to do and would prefer not to?
Anyone with competent knowledge care to chime in with some suggestions please.
Proph
Return to Main Astra K chat
Users browsing this forum: andreyzh, mattonecz and 6 guests
