Install dual rear USB charging points
Re: Install dual rear USB charging points
Postby tukelo15 » Thu Jul 21, 2016 7:10 pm
hello cornishtaz . Can you tell me the piece to connect usb. Thank you
tukelo15
Postby tukelo15 » Thu Jul 21, 2016 7:11 pm
tukelo15
Postby UKtekkie » Sat Oct 29, 2016 11:19 pm
Has anybody done this in a car with a handbrake? I think it's a bit trickier than one with an electronic brake and I'm keen to get some advice.
Red Astra SRi Nav 1.4i (150) with Intellilux, Parking Pack, Sunroof, Climate Control, Winter Pack, AGR seat.
UKtekkie
Postby cornishtaz » Sun Oct 30, 2016 7:52 am
tukelo15 wrote:hello cornishtaz . Can you tell me the piece to connect usb. Thank you
You need to connect it the power feed for the aux power port that way power will disconnected when the ignition is off
Postby cornishtaz » Sun Oct 30, 2016 7:53 am
UKtekkie wrote:Has anybody done this in a car with a handbrake? I think it's a bit trickier than one with an electronic brake and I'm keen to get some advice.
I'd have thought the procedure ould be very similar but you'd need to feed the console past the handbrake lever
Postby Johnny86 » Mon Oct 31, 2016 3:20 am
any guide on removing glove box or way to install car dvr? would like like to hide the wires into the fusebox :D
Johnny86
Postby alecsandes » Wed Dec 28, 2016 1:55 pm
Hello Guys,
I'm asking it here maybe you know better:
I have a dashcam but in Astra K the power on the lighter is turned off when turning off the car.
I found also some devices that connect to the battery and power the dashcam constantly, in the meanwhile they check the battery power level but I would not like to install this...
Do you know if it is possible to have uninterrupted USB voltage supply in the car?
Thanks!
alecsandes
Previous
Return to How To
Users browsing this forum: Baidu [Spider] and 3 guests
Vauxhall Astra K Forums
Our Vauxhall Astra K Forums are free to join and open to all. Contact Us.
Copyright 2015. Not associated with Vauxhall.
