Diamond Cut Alloys
Diamond Cut Alloys
Postby DCX » Sun Jan 01, 2017 9:51 am
Can anyone help me please, after keeping these perfect, I hit a curb and damaged the edge section of alloy :( . Does anyone know of a DIY fix please as I am not paying someone to do something I may be able to do.
Astra SRi 1.4i Turbo (150PS) (MY2016)
DCX
Re: Diamond Cut Alloys
Postby cornishtaz » Sun Jan 01, 2017 11:04 am
Not a diy repair I'm afraid will need a specialist and could cost between £60 -100 depending on where you are
cornishtaz
Postby DCX » Sun Jan 01, 2017 11:14 am
Ughh :( may just fork out and get a new alloy and keep that as my spare
DCX
Postby cornishtaz » Sun Jan 01, 2017 11:37 am
Just get it repaired a new wheel is going to cost you £330 then you've git to get tyre and tpms sensor swapped without damaging the tpms sensor
cornishtaz
Postby DCX » Sun Jan 01, 2017 12:53 pm
Well it was wheel off and into the workshop, managed to get it to a finish and coat that I was happy with :)
DCX
Postby DCX » Sun Jan 01, 2017 2:21 pm
Well wheel is back on the car and this was the finished result.
DCX
Postby Proph » Sun Jan 01, 2017 2:33 pm
Great results...what were the steps and tools you used?
Proph
Postby DCX » Sun Jan 01, 2017 2:55 pm
Thank you Proph :)
1. Cleaned out the scrape with Janitol general cleaner 1:4 water
2. Rinsed
3. Taped off all areas not to be touched
4. Used wet and dry gradually from 240 > 600 > 1200
5. Buffed the area with rubbing compound to get it to blend in better
6. Used a clear coat laquer for 2 coats.
7. Allowed it to dry fully under a uv lamp.
8. Waxed the entire wheel with Soft99 Fusso wax.
9. Fitted back on to the vehicle.
Took a few hours to acomplish but its saved me quite abit of money.
DCX
Postby Proph » Sun Jan 01, 2017 3:25 pm
Wow great job, your a dark horse sounds like you have your own workshop and the full array of tools, really pleased you got it looking like it was never damaged.
I have a scratch in my alloy do you think I could use the same procedure?
Proph
Postby DCX » Sun Jan 01, 2017 3:26 pm
Throw up an image of it, lets see what you have. :)
DCX
Next
Return to How To
Users browsing this forum: No registered users and 2 guests
