Subwoofer and Amplifier install
Postby christ_106 » Sat Dec 31, 2016 10:22 am
Okay, so here we go....
First thing is to fit a remote source to turn the amp on and off with a switched live. Theres maybe a few different places to do this but the norm is the cigarette lighter/ 12v socket. If you have the Sports tourer you'll probably find one easily accessible in the boot, but for us super hot hatches, I'll cover the front.
Start by removing the panel to the cabin fusebox and the air con controls...
The panel unclips from the left hand side and unhooks from the right so give it a tug from the left...
The flower flex will have a similar arrangement, you'll just have an added step to disconnect the power to it to remove the unit completely.
The air con controls have 2 push clips holding it in place, with the fuse panels removed, you'll be able to grab it from below and give it a tug to disengage the push clips...
Once out, remove its connector from the rear and set aside.
Remove the gaitors around the gear shifter and handbrake (if you have a manual and not electronic parking brake). Both unclip from the rear and sides and unhook at the front, so start at the rear and work your way forward. U may need a small flat tool to help get it started, especially on the gear knob gaitor, but I managed without. Once the gear gaitor is removed, you will have access to 2 torx screws on both sides which secure the trim with the lower console control buttons.
Remove these and unclip the lower console controls. The controls have tabs that clip over lugs on the console so be gentle and start from the top at the buttons and work your way down, you may need a flat tool to help lift the tabs over the lugs as you progress...
Once you have removed the connector to the console controls, you will now be able to remove the centre console by pulling it rewards. The console has 8 push clips holding it secure, located from centre to top of console, just remember to pull straight back because there is also plastic locator pins which may snap if you take it out skewed...
Unclip the 2 side panels in the footwells, secured with plush clips...
Remove the 4 screws, 2 on either side, 2 at front and 2 at rear, of the lower console and armrest using a 7mm socket...
Astra SRi Nav 1.6i Turbo (200PS) S/S (MT6) - MY16.5
Carbon Flash
christ_106
Re: Subwoofer and Amplifier install
Postby christ_106 » Sat Dec 31, 2016 11:34 am
Now lift the lower console from the rear of the arm rest and pull rearwards to unclip from the dash. There is 2 push clips at the front securing it to the dash...
You only need the lower console pulled rearwards a little to get access to the 2 connectors at the front. The small connector is the USB, and has a button to push to allow you to pull it out. The large harness connect has a button just above the purple locking arm. Push this, lift the arm and disconnect...
At this point I decided I was going to take my switched live source from this harness. If your taking if from the 12v socket, the socket will just push out of the lower console giving you access to the wires. There is 3 wires into the 12v socket, black = ground, purple = switched live and yellow = lights live (only live with your lights on)
Back to our harness...
The harness cover can be removed. The black cover has tabs that fit over 2 lugs on the brown connector. Separate the cover from the connector...
In this connector, there is a purple/blue striped wire which is a switched live. I crimped on a trimmed-down spade connector to my remote wire and pushed it into same socket as the purple/blue striped wire which was pretty secure...
Now feed the remote wire to the right hand side of your car around the footwell, securing it with cable ties to avoid rattle.
You can now retrace your steps to put the centre console back together.
Now for the audio output source...
On the right hand side of the car, behind the dash is the radio unit.
LEFT HAND DRIVE CAR - it's behind the glove box which is secured with screws and push clips. There is 2 screws behind the side panel of the dash, with the door open, which has the air bag switch. This panel just unlips to give you access to the screws...
RIGHT HAND DRIVE CAR - it's behind the small storage cubby to the right of the steering wheel. Open the storage cubby and at the rear, squeeze the 2 sides together to get the rear the to pass the dash completely. Then the storage cubby can be unhooked from its hinge and removed...
The radio unit is the silver box with multiple connectors plugged into it at the bottom. The connector we're interested in is the green one. Disconnect the green connector for access...
The 4 pairs of wires (eight wires in total) to one side of the connector is the speaker wires. The other 2, red and black, appear to power the navi 900 display on the centre console.
Solid colour = +positive, striped = -negative
LEFT REAR AUDIO- solid green and green/black stripe
RIGHT REAR AUDIO- solid white and blue/black stripe
FRONT LEFT AUDIO- solid blue and brown/blue stripe
FRONT RIGHT AUDIO- solid yellow and yellow/black stripe.
When I first connected this, I mistakenly tapped 1 rear and 1 front, and when the front was tapped, it made my tweeter cut out. Make sure you tap the rear audios signals.
Now it depends on your amplifier whether it can accept high level input, but if it can't, you'll be connecting a high to low audio signal converter to these green & green/black striped and white & blue/black stripe wires. My amplifier can accept high level audio, so I just cut down an old RCA phono cable to approx 1 foot (30cm) split the wires and crimped the ends of the bare wires so I could push them into the same socket at the existing wire sets.
My crimps needed altering a few times to get them to fit and tidied the wires with electrical tape...
Carbon Flash
christ_106
Postby Proph » Sat Dec 31, 2016 12:36 pm
Wow
Proph
Postby christ_106 » Sat Dec 31, 2016 12:44 pm
At the other end of my RCA phono lead, I connected a bass/volume level control knob which has input output rca phono connectors. I plugged my custom RCA phono lead into the input and connected my main RCA leads into the output jack's. This bass level control is going to be fixed into my storage cubby for easy access and control of my bass volume...
Now run your main RCA leads and remote power cable together to the boot, tucking the wires under the plastic trim between the floor and the doors. Remember and secure loose cables behind the dash with cable ties to avoid any rattling.
When you get to the rear seats with your cables, you'll have to lift the rear bench to feed your cables into the boot. The rear bench is secured to the chassis with 2 pretty tough push locks at the front, and hooks at the rear. The 2 at the front are at the centre of the left seat and the centre of the right seat. Stand outside the car facing the front, lean in and grab the bench with both hands between the front of the bench and chassis, with both hands on the same side of the push lock pin/loop at the middle seat side / centre of the car / inner side and tug as hard is you can. First time I did it I used a large socket ratchet to pry it off by.putting it between the bench and chassis and lifting up, but again keep it to the side of the pin/loop closest to the middle seat...
You only need to lift one side to continue to feed your cables to the boot.
Now to the boot...
You'll need a good ground for your amplifier. I removed one of the silver hoops for strapping down and scrapped away the paint using a Stanley blade/ box cutter. Make a good job at removing all the paint so you have good contact with the bare metal. I crimped a hoop connector onto my ground wire and screwed this back below the silver boot hoop...
If you havent done so already, which I would advise, disconnect your -negative to your battery. Connect your amplifiers fused power lead to your battery +positive terminal. Connect your remote power to your amp, then your power from battery, then your ground cable. Put your power fuse if your leaving it until last and reconnect your -negative battery...
Get your capet back down, position your amp and sub, connect your amp to your sub with your speaker wire...
JAMMING!
Jump in your car, start her up, set the time and date, take her for a spin to get the outside temperature reading reset and to get rid of the possible ice warning and CRANK IT UP!¡!¡!¡!
:twisted: :twisted: :twisted:
But this is just a guide not definitive instructions, every car is different... myself or no one else here is responsible for anything that happens as a result of you making modifications to your car.... Least of all vibrating mirrors or cable tie tail rattles!
:lol:
Anyway... Phase 2 will be a proper custom boot configuration, I'll post in future!
HAPPY NEW YEAR!
Carbon Flash
christ_106
Postby Proph » Sat Dec 31, 2016 12:53 pm
Great write up Chris, so detailed and I applaud your skill and knowledge regarding how to do this as it seems very complex compared to the old days of fitting an amp and sub to a car.
It's great to have another post with details and pics on the removal of the central console.
This is one mod I won't be attempting for a few reasons:-
° I'm happy enough with the sound quality at the moment.
° the complexity scares me on a car with warranty
° if and when I decide to trade mine in for another car I don't want to have to remove it all again our sell it witch the extra equipment
Maybe if I had the 200hp model and was definitely keeping it once fully paid for I would contact you and offer to pay you to fit mine lol.
Well done mate, hopefully at the meet in June if I can make it I can hear how good your system sounds.
Proph
Postby christ_106 » Sat Dec 31, 2016 12:55 pm
Thanks Proph, it taking a few days and a complete dash and interior tear down to figure out what the hell I was doing. There may even be a better way of doing it too. Even my custom RCA phono lead will get better connection fitted to them, I just couldn't get bullet or spade connectors to fit so I kept cutting 'em up with tin snips to make them fit... I'm looking into better crimp pin connectors... But I've no patience waiting for them to arrive... and I've been at this for 3 days now!
Like you, I don't really want to void my warranty, so everything has to be reversible without cutting and splicing wires, and quickly removed if need be.
Thanks for the comments, I had to post this, I just know there will be plenty of good people out there with awesome cars who need this modification know how!
Thanks again!
Carbon Flash
christ_106
Postby cornishtaz » Sat Dec 31, 2016 1:26 pm
Excellent how to Chris. That's pretty much exactly how my audio guy fitted my amp
cornishtaz
Postby christ_106 » Sat Dec 31, 2016 2:19 pm
Thanks Cornish, TBH, I seen your level control in your storage cubby and thought.... I'm having that! :lol:
I bought a multi meter from screwfix for £10 and every free connection that didn't have a fuse behind the powerflex seems to be constant live, no switched, which was a bit of a bummer, so the lower console harness seemed to be the best bet.
Also, for the life of me, I couldn't remove the lower console completely at all! I couldn't get it passed the handbrake lever. I removed the rear panel which holds the dual rear usb, but still, the handbrake lever got in my way and I couldn't see how to remove the lever or separate the armrest from the lower console... if it even does? Not that I needed to remove it but when your that far gone, you want to go all the way for future reference... Say for handbrake adjustment?
Carbon Flash
christ_106
Postby Anupanu » Sun Jan 01, 2017 12:57 am
Great posts, but did you look in the fusebox in the boot for switched power?
Luxor Blue Insignia Elite Nav ST CDTi 163
Emerald Green Astra Elite CDTi 110 with Parking Pack, Driver Pack , Intellilux and Power Drivers Seat
Anupanu
Postby christ_106 » Sun Jan 01, 2017 4:34 pm
Anupanu wrote:Great posts, but did you look in the fusebox in the boot for switched power?
Agreed...
...However....
...I couldn't find the rear fuse box as described in my manual!!!...Typical huh? So who out there is missing their rear fuse box? Is it engine/model specific? Is it Model Year specific?
Perhaps a rear interior tear down will reveal one, but I'm not convinced!
I plan on building a custom deck to house the sub, amp and an additional aux socket, so I'll try pin point a closer rear source then. Even in the battery compartment I'm unsure I'll find one, but i'll certainly try! Open to suggestions everyone!!!
Carbon Flash
christ_106
Next
Return to How To
Users browsing this forum: No registered users and 2 guests
