Fuel gauge reading
Re: Fuel gauge reading
Postby Paulch » Fri Oct 28, 2016 10:25 am
Asher wrote:I left mine in to get fixed, dealer told me they done a software update, but its still doing the same as before. I read that after the update the fuel gauge does a sweep when you turn the ignition on......is this only related to diesel models? As my 1.4 150ps doesn't do it.
Before the update my Petrol model didn't do the sweep but afterwards it did.
SRI Nav 1.6T (200). Parking pack, Climate control and spare wheel. Power Red.
Paulch
Postby cornishtaz » Fri Oct 28, 2016 10:49 am
After my update the speedo and rev needles sweep but not temp/fuel gauge
cornishtaz
Postby Jeff16150 » Fri Oct 28, 2016 11:17 am
Have never had any issue with the fuel gauge or My Vauxhall app not indicating full and all of my gauges sweep.
Summit White 1.4T 150 Elite Nav Automatic (Ordered 05.05.2016, Delivered 19.07.2016)
Parking Pack, Power Tilt & Slide Sunroof, Steel Emergency Spare Wheel.
Jeff16150
Postby cornishtaz » Fri Oct 28, 2016 11:31 am
You'd think seeing as some cars are unaffected Vauxhall must have the correct software so I wonder why their not uploading it onto the affected cars
cornishtaz
Postby Paulch » Fri Oct 28, 2016 1:22 pm
cornishtaz wrote:After my update the speedo and rev needles sweep but not temp/fuel gauge
This would suggest there is more than one version of the update around. Unfortunately I don't know of a way to see which version is now installed as the version numbers given in the NAVI900 unit didn't change on mine after the update.
Before the update none of my needles did the sweep now all four do.
Paulch
Postby cornishtaz » Fri Oct 28, 2016 2:54 pm
I've also had a new set of clocks fitted due to the needle reading below empty which was different when compared to another one in the workshop. When mine is on empty I've still got 60 miles range
cornishtaz
Postby Jeff16150 » Fri Oct 28, 2016 5:36 pm
cornishtaz wrote:You'd think seeing as some cars are unaffected Vauxhall must have the correct software so I wonder why their not uploading it onto the affected cars
Training issue and ability of technicians to interpret data?
Jeff16150
Spare wheel
Postby Swagger » Sat Oct 29, 2016 9:12 am
There's no room in my boot under carpet for a spare wheel. Just a flat floor with the car battery.
2016 16 plate 1.6i turbo 200 bhp
Surely the cars should all be the same
Swagger
Spare wheel
Postby Swagger » Sat Oct 29, 2016 9:17 am
No room in my boot for a spare wheel. If I lift carpet it's just a flat floor with the car battery.
Swagger
Re: Spare wheel
Postby Paulch » Sat Oct 29, 2016 9:24 am
Swagger wrote:There's no room in my boot under carpet for a spare wheel. Just a flat floor with the car battery.
Mine was factory fitted so I assume it has a different under carpet arrangement.
Paulch
PreviousNext
Return to Faults & Technical
Users browsing this forum: No registered users and 4 guests
