Issue with static nose
StevenD
Post by StevenD » Wed Jan 11, 2017 5:14 pm
I am looking to find out if anyone else has had a similar issue to this.
I have had my 1.4T SRI for 2 weeks now with no issue. I started the car today and the radio was very faint with a loud static noise. The noise goes away when the radio is off but the static noise returned when i was using the indicator (while the radio was off and i had turned the volume completely down before switching it off) and goes off when the indicator stops.
It seems to have resolved itself but i restarted it about 5 times and it was there, drove home with the issue. Went back to the car after about 30 mins and it was fine.
Anyone else have this issue?
ArcanumFox
Re: Issue with static nose
Post by ArcanumFox » Wed Jan 11, 2017 5:41 pm
It's a known concern and a software update is available for your radio unit.
Did one today at work on an Astra K.
Book in at a dealer and refer them to 'DACT4184- Field fix software R4.0 IntelliLink BYOM2 radios (ioA / ioB)' on Find Answers (GM's internal database of known concerns, bulletins, etc).
Even if they can't replicate fault on the day, push for that update as it will fix the issue.
Vauxhall Service Advisor in the Midlands
Astra K 2016 Registered 12/11/2015 1.4 Turbo (150BHP) SRi Nav Carbon Flash (Black)
StevenD
Post by StevenD » Wed Jan 11, 2017 9:31 pm
Cheers for the information. Much appreciated.
I'll get them on the case
PeteVX16
Astra Model: 1.6T 200 Elite
Astra Options: Park assist,Power seat,Eectronic key,LED rear
Post by PeteVX16 » Thu Jan 12, 2017 1:06 pm
I have too, posted about it after the New Year, weird isn't it. Also have had a 'growling' sound of the brakes functioning through the speakers and/or the volume muting when touching the footbrake. My dealer informed me pre-Christmas of an update available so will definitely get it booked in now that we have expert inside information to ensure the correct patch is applied.
Thanks for the info ArcanumFox.
1.6t 200 Elite. Advanced park assist. LED tail lights. Powered driver seat. Keyless entry and start. Spacesaver wheel. Pearlescent asteroid grey.
Astra, the way forward.
mattonecz
Astra Model: K
Astra Options: front and rear park. sensors, dual clima
Astra Colour: white
Post by mattonecz » Thu Jan 12, 2017 1:12 pm
ArcanumFox wrote:It's a known concern and a software update is available for your radio unit.
Cool, thats what i need aswell.
Can you get any info about updates for 1.4T engines?
1.4T 92kW, Enjoy - Dual AC, front and rear park sensors, 17"
SPARTAN_SAM_H
Astra Model: Elite Nav 1.4t
Astra Options: Heated Seats/Steering Wheel, Front/Rear Sensors
Astra Colour: Deep Sky Blue
Post by SPARTAN_SAM_H » Sun Mar 12, 2017 6:49 pm
I think I have this issue also, though the static noise is much worse on the FM signal rather than anything else..
Got mine booked in for software check to see if I have the correct updates,
Does anyone know if I do get an update will this include Android Auto functionality?
Crunchynut
Post by Crunchynut » Sun Mar 12, 2017 7:08 pm
If they do an update does it include all patches up to that date, or do you have to ask for specific ones?
Elite 1.6 CDTi 136ps Hatch
PeteVX16
Post by PeteVX16 » Mon Mar 13, 2017 11:31 pm
Another one eh!
Brake sound through speakers. Car went in a few weeks back, they replicated the fault and after checking say it is due to a faulty high level brake light, new one ordered and due to be fitted at end of the month when in for its 1st year service. Apparently VX UK had a logged fault earlier on another car and the fix worked, fingers crossed it does. I did ask them to do the software update the forum here advised a few months back, is this the DACT 4184 by the way, not sure they have done that though?
Buzzing with audio off from indicators, as I mentioned in my previous post, the mad buzzing fault appeared on the car over the new year. I'll also ask about the DACT 4184 upgrade for this issue.
Arcanum Fox, do you think the two faults are linked and have you heard of the high level brake light fix??
Users browsing this forum: No registered users and 1 guest
