Flywheel + Clutch DMF
Re: Flywheel + Clutch DMF
Postby Kristis » Sun Jan 08, 2017 12:43 pm
Yes there is and dealership with even Opel's help is not capeable to fix the splutter/oil/smoke :) so im just waiting for the engine to blow now :)
'16 Opel Astra 1.4T/150hp/RED/Innovation
Kristis
Postby luke659 » Tue Jan 10, 2017 10:44 am
Just heard back from the garage. They are going to replace the flywheel as that's the fault. The clutch is fine, however if I want that changed I have to pay for it.
What do you recommend guys??
luke659
Postby mattonecz » Tue Jan 10, 2017 10:54 am
you gotta pay for flywheel? so they say its yours fault?
1.4T 92kW, Enjoy - Dual AC, front and rear park sensors, 17"
mattonecz
Postby luke659 » Tue Jan 10, 2017 11:44 am
Sorry matt I should have made that clearer. Vauxhall are going to replace the flywheel under warranty :). However, if I want that clutch replaced I have to pay as its not "broken"
I always assumed if you changed one you should change the other. The Vauxhall engineer said he's happy or the old Clutch to go with the new Flywheel.
What do you think?
luke659
Postby mattonecz » Tue Jan 10, 2017 12:05 pm
oh, good :)
yeah its usually changed together but it may be ok since you dont have too many miles on clock
when its changed together its after around 100K miles or more
mattonecz
Postby luke659 » Tue Jan 10, 2017 12:13 pm
I said the same to them but the technician said its fine so I will trust his word. I have asked for all of this in writing encase 6 months down the line it all breaks again and the blame is on me.
They have advised me to change the clutch with the flywheel but I will have to pay for this as the part is not broken. Even though like you said Matt they "should" be done together.
I am also going to contact Vauxhall and complain as they "should" replace both of these parts together plus they have had my car for a week now and still no work done.
luke659
Postby Kristis » Wed Jan 11, 2017 1:45 pm
Changing the flywheel without clutch is the same as changing brake disks yet leaving old brake pads :)
Kristis
Postby luke659 » Wed Jan 11, 2017 3:07 pm
I thought the same but if the Vauxhall engineer is happy to do this then oh his/head be it.
luke659
Previous
Return to Faults & Technical
Users browsing this forum: Google [Bot] and 1 guest
