I love my car .... but ...
Re: I love my car .... but ...
Postby pmickal » Mon Jan 02, 2017 11:20 am
Swagger wrote:I also get the noise at the back of my car but to me it's more like a turbulence sound. I will mention it next month at its 1st service
Yes, same noise here, but not all the time. It started after I switched summer tyres to winter.
Opel Astra K 1.4 T Innovation, 92 kW, MY 17
pmickal
Postby Mowerman » Mon Jan 02, 2017 8:12 pm
Thanks for all the responses people - car booked in this week to get the bearing noise looked at.
I've been around enough old cars to know what a noisy wheel bearing sounds like - although with less than 400 miles on it there's no way it's worn - I suspect it's just a bad bearing from the factory.
I hope the light sensor issue can be sorted - the dim dash and info screens are really starting to irritate me!
Mowerman
Postby Anupanu » Tue Jan 03, 2017 11:07 am
The light sensor issue irked me for the first time yesterday, when trying to use Google Maps on Android Auto the map goes very black at night, OK at night, not good when you are trying to follow directions and the auto lights keep on going on and off in the middle of the day, I didn't think it was that murky but they started to muck about after they came on when I went through the very short tunnel under the Clifton Suspension bridge
Luxor Blue Insignia Elite Nav ST CDTi 163
Emerald Green Astra Elite CDTi 110 with Parking Pack, Driver Pack , Intellilux and Powered AGR Sports Seats
Anupanu
Postby Mowerman » Tue Jan 03, 2017 4:45 pm
Yes - my problem exactly :-(
Mowerman
Postby Sri150 » Thu Jan 05, 2017 12:54 pm
I've noticed that the light sensor seems to check the light level when you start the car, but then maybe it checks it at a set interval after that, and doesn't monitor the light constantly. I say this because I had the lights on, then , the car went into blazing bright sunlight, and still the lights would not turn off . I turned the ignition off, restarted while in the direct sunlight, then the lights went off.....
Sri150
Postby Mowerman » Sun Jan 08, 2017 6:23 pm
Well .. car been back to the dealer for the bearing noise and sensor issue.
Short answer - we can't find anything wrong. This I can only assume us because they employ deaf mechanics? ??? No point in arguing with them - the car has 420 miles on it so by the time it's due for its 20000 mile service it will sound like concorde taking off - if it hasn't fallen off by then.
The light sensor issue is more interesting. The dealer claimed that it was working fine - in spite of the fact that when I got in to take it away in blazing sunshine it was in night mode! I didn't have time to argue at the time so I told then I wasn't happy and would be back in the morning.
When I got in the car the following morning the infotainment system appeared to have done a factory reset - it was asking for a language selection and having selected English there are some subtle changes to the interface - and the auto lights work! !!
Do vauxhall do OTA updates? I can't tell for sure as I didn't make a note of the software version when I got it.
Mowerman
Postby Anupanu » Sun Jan 08, 2017 8:53 pm
Mowerman wrote:Do vauxhall do OTA updates? I can't tell for sure as I didn't make a note of the software version when I got it.
That's interesting, perhaps we could compare software versions?....?
Anupanu
Postby paulfletcher » Mon Jan 09, 2017 10:17 am
Hi,
I share your issue about the automatic light control issues.
This is a copy of an email I sent to Vauxhall and their reply.
I have read several posts on this topic. Perhaps if more owners e mailed Vauxhall direct they might come up with a solution to this problem.
Hi,
I wondered if you could advise me with regard to a problem I am having with my new Vauxhall Astra, registration number YJ16 BHH. Purchased from Evans Hallshaw, Horsforth, Leeds,
West Yorkshire, on the 25th July 2016. It has currently 2,000 miles on the clock.
The problem relates to the day and night light sensor or it's associated electronics.
The interior dashboard and infotainment system are illuminated via this sensor which detects the degree of outside light density and switches the lighting to day or night mode. My car has demonstrated a fault with this
unit ever since I have owned it. I can be driving along a clear road in bright sunlight and if I drive it beneath a tree for example it will go from daylight to night mode in an instant but then when I drive back into broad daylight the screen and dashboard
illumination remains in night time mode for the rest of the journey,
(yesterday for a further 200 miles in bright sunshine in night time mode!), blacking out the screens. If the sun is behind me it reflects on the dashboard and I can't see the digital speed indication which I use all the
time. Initially I was able to rectify this problem by stopping the car, removing the ignition key, opening the drivers door, locking the car with the key, unlocking the car , opening the door and then starting the ignition. This performance seemed to re set
everything but that sequence of events no longer works and the dashboard lights and infotainment system are almost always in night time mode, this is without having the light switch set in automatic lighting mode otherwise I would be driving in bright sunshine
with the dipped headlights illuminated!
I have now set the infotainment system to daylight mode but the dashboard light still remains dimmed out. Then when I drive at night I have to re set the infotainment to night time mode to stop the dazzling from that unit
- a right performance!
I have had my vehicle to the dealers twice about this problem and they have put it on their diagnostics and sent the result to yourselves and have returned the vehicle saying that no problem could be found. The circumstances
I have described above are not an uncommon problem with the Astra and other Vauxhall models and was even present on the J series Astra according to Astra owners forums I have read.
Can you advise me what I need to do to resolve this issue as I find it quite annoying and dangerous as I can't clearly see what speed I am doing when in night time mode during broad daylight.
Is there a software update available or one in the pipeline or do you think my vehicle needs a new light sensor?
You advise would be appreciated.
Regards,
Paul Fletcher
REPLY
Dear Mr Fletcher
I write in reference to your Vauxhall Astra registration number YJ16 BHH.
I am sorry to hear of your recent experience regarding your vehicle and can understand your reasons for contacting us.
Our technical team have confirmed the issues experienced will be resolved by a new software update.
Regrettably we do not have an exact date for the release of the software update, however after speaking to our internal technical team we anticipate the software will be released next year.
The dealership will be made aware once the update has been released, from there they will be able to book the vehicle in for this to be completed.
I understand this may not have been the response you had hoped for and apologise for any inconvenience caused.
Once again thank you for contacting Vauxhall Motors and allowing us the opportunity to assist.
Kind Regards
Rebekah Thompson
Infotainment Agent
This email has been sent from General Motors Limited
Registered in England 01682792
Registered Office : Griffin House, Osbourne Road, Luton, Beds, LU1 3YT, Telephone: 0844 369 0112
VAT Number 382 1581 51
paulfletcher
Postby christ_106 » Mon Jan 09, 2017 11:05 am
Thanks for sharing! Great email and work getting information from the horse's mouth! Good to know, keep us posted!
Astra SRi Nav 1.6i Turbo (200PS) S/S (MT6) - MY16.5
Carbon Flash
christ_106
Postby PACMANIA » Mon Jan 09, 2017 12:01 pm
Vauxhall knows sweet fa about the car. Best asked Opel via Facebook or direct. I bet there not English technician working in Germany on this car. Opel have always got back to me within 48hours of asking a question.
PACMANIA
PreviousNext
Return to Faults & Technical
Users browsing this forum: Google [Bot] and 3 guests
