touchscreen projection
Postby coldplayfan » Tue Dec 20, 2016 9:55 pm
has anyone had problems connecting there fones to the projection option.mine says error use a supported device to continue.i have the galaxy s6 os 6.1 marshmallow.its not the cable because someone with same fone tried and it worked through android auto.also listed on the screen is option for 2 usb sockets one in armrest anybody know were the other would be located?its 66 plate sri.thanks in advance
coldplayfan
Re: touchscreen projection
Postby 1900sr » Wed Dec 21, 2016 6:47 pm
There isn't a second USB, it may technically be possible to put a two way hub into the one in the console then USB2 on the head unit would come into play. I did try it when I first got my car but couldn't get it to work reliably.
If someone with the same phone as you tried their phone using your cable and it worked that suggests the problem is with your phone (assuming they were using your car), but I wouldn't know what it was. I assume you have downloaded Android Auto onto your phone?
1.0i Turbo SRi, Power Red.
1900sr
Postby Andrew72 » Wed Dec 21, 2016 7:39 pm
It's possible that you may need the update applied to your car.
I had mine done two weeks ago and I haven't had any problems.
I have the Samsung Galaxy s6.
Andrew72
Postby kierweb » Tue Jan 10, 2017 6:12 pm
Hey,
I have a Samsung S6 Edge and Projection (aka Android Auto) has worked since the car was upgraded to support it.
Astra SRi 1.4T (150), Silver, 18" alloys, Tints, Winter pack, Parking Pack, Tinted Windows
kierweb
Postby sps170373 » Fri Jan 13, 2017 3:51 am
2nd USB is probably for the flexbar phone holder option
SRI 1.4T carbon flash 18" bicolour alloys
sps170373
Postby 1900sr » Fri Jan 13, 2017 8:04 am
sps170373 wrote:2nd USB is probably for the flexbar phone holder option
No, the flexbar doesn't give you an input to the infotainment system, only a power source.
1900sr
Return to Faults & Technical
Users browsing this forum: No registered users and 10 guests
