Rear fuse box cover
Rear fuse box cover
Postby M1chaelR » Thu Sep 08, 2016 10:25 am
Hey all, me again!
The fitter had to wire my dashcam to the rear fusebox but the cover would not fit back on due to the size of the extra kit from the nextbase kit.
Does anyone know if it's okay/safe to leave the cover off? It's behind the main cover in the boot anyway. Any thoughts appreciated.
M1chaelR
Re: Rear fuse box cover
Postby astramaster » Thu Sep 08, 2016 11:27 am
I think there is no problem leaving it open.
Is it a front or rear dash cam?
Do you have photos of final installation?
astramaster
Postby SwissTJ » Thu Sep 08, 2016 1:16 pm
<sarcasm mode: on> Yup, fine to leave all those electrical connections and fuses unprotected, GM put a cover over them for fun... <sarcasm mode:off>
Is that rather horrible green & yellow spliced cable the work of your fitter?
Views are my own
SwissTJ
Postby fryrpc » Thu Sep 08, 2016 1:28 pm
<sarcasm mode: on> Shocking if it is<sarcasm mode:off>
Emerald Green Sports Tourer 1.6CDTi BiTurbo 160 Elite Nav with IntelliLux and Parking Pack - delivered 18/05/16
fryrpc
Postby M1chaelR » Thu Sep 08, 2016 3:52 pm
astramaster wrote:I think there is no problem leaving it open.
It's a front cam. It is installed like so:
SwissTJ wrote:<sarcasm mode: on> Yup, fine to leave all those electrical connections and fuses unprotected, GM put a cover over them for fun... <sarcasm mode:off>
It is, Halfords did it. I'm not sure whether to ask my dealer if they can tidy it up. What would you suggest?
Update: I've booked it into my dealer for them to have a look and check it over. I don't want to take any chances (these things always happen to me).
M1chaelR
Postby cooldad » Thu Sep 08, 2016 4:40 pm
If I may say so, it looks a bit of a mess!! ;)
Why don't you take it back to Halford's and get them to sort it? I agree that the fuse box cover is better on than off. There must be a way of accommodating the wiring more neatly, so allowing the cover to be replaced.
cooldad
Postby M1chaelR » Thu Sep 08, 2016 4:51 pm
cooldad wrote:If I may say so, it looks a bit of a mess!! ;)
It looks worse in the picture (which I've now brightened) than it is but it's still not that tidy. The wire spliced by the green and yellow tape comes from the front and then goes into the fuse box. I can only assume that the original wire wasn't long enough.
I think it is the fault of the nextbase kit and the attachment that they have provided. A simple mod to the cover would allow for the cover to be refitted but I'd rather not hack away at it myself. I have a good relationship with my dealer so I'm happy for them to help check it over and sort it. Im not one for taking it back to somewhere that has caused an issue in the first place.
M1chaelR
Postby albany » Thu Sep 08, 2016 5:58 pm
Mmmn every picture tells a story stop making excuses and get it back to Halfords its pathetic, what I would like to know what kind of connection lurkes under the insulation tape, also note its colour is that wire live or earth.i
Tech Line 1.4t 125ps Emerald Green, space saver wheel.
albany
Postby M1chaelR » Thu Sep 08, 2016 7:36 pm
albany wrote:Mmmn every picture tells a story stop making excuses and get it back to Halfords its pathetic, what I would like to know what kind of connection lurkes under the insulation tape, also note its colour is that wire live or earth.i
I would but I wouldn't be happy that they'd sort it properly, I'll be much happier with the dealer who are seeing it on Tuesday. I'll put it down to experience to not let Halfords fit anything, I was a bit dubious to begin with. I'm sure there's a fusebox behind the lower part of the dash that it could have been installed into.
M1chaelR
Postby cornishtaz » Thu Sep 08, 2016 7:53 pm
Power could have been taken from fuse 4 in the centre console fuse box as this supplies the Auxiliary power outlet
cornishtaz
Next
Return to Faults & Technical
Users browsing this forum: Baidu [Spider], M1chaelR, Razormatt and 7 guests
